Fatal error: An unexpected error has occurred: Method not found: “!!()[]system.Array.Empty()’. System.MissingMethodException: Method not found: ‘!!()[] System.Array.Empty()’. at Ans.SceneGraphChart.View.ScenceGraphView..ctor
April 5, 2023 at 2:32 pmFAQParticipant
Solution: The issue has been identified that the prerequisite latest version .Net Framework is not installed successfully in the Client machine. Installing .Net framework R4.6.2 Installation has resolved it.
- Failover feature ‘Discovery – Level 1’ is not available
- Q: How do I set the license server from my client machine?
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
- Unable to start the Geometry or Mechanical Editor (Linux)
