March 17, 2023 at 8:58 amFAQParticipant
The problem here looks to be related to the fact that some of the TRS interfaces are Fluid-Solid, but the code is trying to trigger a coupled partitioning across those interfaces and we generally do not allow that for Fluid-Solid. There is a simple work-around for now: set the expert parameter ‘part frozen rotor intersect = f’ and the case will run.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
