April 5, 2023 at 2:32 pmFAQParticipant
The error may be caused by negative input for mass in 6dof properties. Please make sure that your inputs are correct like mass, center of gravity etc. If you are using UDF then make sure that it provides correct output.
- How can I select interior faces and other entities that are inside the model?
- Left-handed faces troubleshooting
- Skewness in ANSYS Meshing
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Running Python Script from Workbench
