Can surface reaction cases be accelerated by means of ISAT? Is ISAT compatible with surface reactions?
March 17, 2023 at 8:59 am
FAQParticipantSurface reactions are compatible with ISAT. Thus, ISAT can be activated in surface reactions cases and the cases can be run. However, ISAT does NOT accelerate surface reaction cases, since it has no no effect on surface reaction. Till Release 19.2 documentation a clear note on this limitation is missing. This has been corrected in the documentation of release 2019R1.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Configuring and Solving the Chemical Species Transport in Fluent
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
