Can an Elasto-Plastic model like Bilinear/Multilinear be used for Brittle plastic material instead of Elastomeric model
May 15, 2023 at 8:32 am
Solution
ParticipantPlease refer to the attachments to access the solution.
1. 2053508.pdf
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
