Tagged: 17, fluent, fluid-dynamics, General, MRF/Frozen Rotor, Rotating Flows, rotating-machinery
March 17, 2023 at 1:10 pm
SolutionParticipantWhen considering a “Moving Reference Frame” (MRF) zone in uniform cross flow, an artificial pressure gradient is created. Please consider the attached file “2041678_False pressure gradient with MRF in uniform cross flow.pdf” for some explanations on this limitation of MRF approach.
1. 2041678.pdf
2. 2041678_False pressure gradient with MRF in uniform cross flow.pdf
- Skewness in ANSYS Meshing
