June 5, 2023 at 7:05 am
FAQ
ParticipantTwo options. 1. Under Repair there is a “Fit Curves” tool. You can use this to replace a set of curves with lines/arcs or a spline. You can set the allowable deviation in the options on the left side of the screen. 2. Concatenate the curve. Click the point in between two curve segments and hit “Fill” tool. This will combine the two curves together into one curve body.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
