Tagged: A Arm, ansys-mechanical, ansys-student, baja, fea, fsae, Suspension Arm
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantThis video demonstrates how to do fatuque analysis of a formula SAE suspension control arm. For any questions/support, join ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
