A simulation setup with flamelet, radiation and heat transfer crashes after a certain number of iterations with the error: Fatal bounds error detected ————————— Variable: A1CH2OH C7H8O.Specific Heat Capacity at Constant Pressure Locale : Domain 1 +——————————————————————–+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine ENFORCE_BOUNDS | What is the reason?
Tagged: 10, cfx-solver, combustion, fluid-dynamics, General, heat-transfer
May 15, 2023 at 8:32 am
- Skewness in ANSYS Meshing
