Tagged: 16.1, Eddy Dissipation, fluent, fluid-dynamics, Species/Reactions, turbulence
January 25, 2023 at 7:17 am
FAQParticipantCombustion proceeds whenever turbulence is present, and an ignition source is not required to initiate it. However, the model requires products to initiate reaction. If you have a steady-state simulation and initialize it, Fluent will set all species mass fractions to 0.01 for the eddy-dissipation ignition (you will also get a corresponding message). This is normally sufficient to start the reaction. When you start your simulation from a previous calculation or first simulate the cold mixing process, you must make sure that products are present. You may have to patch products into the reaction zone to ignite the flame.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
