June 7, 2023 at 7:58 am
Muhammad Usman Shafique
SubscriberHello everyone,
I am trying to simulate flow through injector using VOF model with K-E RNG (swirl dominated flow) on FLUENT 2022 R2. I have distriburted my simulation on 3 PCs(Dell Precision Tower 7910)Â using distrubted memory option in FLUENT. Specifications of PC's are as following:
PC1: MEMORY=64GB, GEFORCE RTX 3090 (24GB) 28 cores
PC2: MEMORY=64GB, GEFORCE RTX 3090 (24GB) 28 cores
PC2: MEMORY=32GB, GEFORCE RTX 1660 (6GB) 16 cores
Fluent is showing that the GPUs are being enabled but during simulation the GPU is not being utilized but only the CPU and Memory. I have also installed CUDA Version 12 for proper intgration but no success so far. If anyone has any idea on how to resolve this issue, kindly let me know.
I am also trying to introduce a new environment variable for proper utilization of GPUs on each device. Kindly tell if its the right approach.
June 12, 2023 at 12:04 pm
Aniket
Forum ModeratorFluent GPU solver is only available at Enterprise license level:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_sec_gpu_solver_starting.html%23flu_ug_sec_gpu_solver_launcher
If you have an enterprise license, please note the GPUs you have listed are not on list of supported ones:
Graphics Cards Tested (ansys.com)
-Aniket
- The topic ‘Zero utilization of GPU despite being enabled’ is closed to new replies.
3882
1414
1241
1118
1015
