Topics relate to Mechanical Enterprise, Motion, Additive Print and more
Winch that Changes Cable Length
    • Eugenio Baita Saavedra
      I am trying to include a Winch that Changes Cable Length for simualting a winch pulling the line, but only the winch type "Maintains Constant Tension" is in the list:
      I have read in Aqwa Users Manual (5.10.11.2) that it can only be used with Linear Elastic, and that's what I am using:
      What could be the reason?
      Regards
    • Mike Pettit
      It looks like you have added your Cable Winch to a stability analysis, where it can only act to maintain a constant cable tension. For a Cable Winch that changes the cable length, the Hydrodynamic Response Analysis Settings 'Computation Type' option needs to be set to 'Time Response Analysis'.
      Generally, I would recommend that you run a stability analysis first (without the Cable Winch), and then link the Solution of this system to the Setup of a second Hydrodynamic Response system, which will be your time response analysis (including the Cable Winch). The stability analysis provides equilibrated initial conditions for the vessel, so avoiding any large forces/moments at the start of the time domain calculation.
      I hope this helps!
      Mike
      Hello Mike,
      you are right. I discovered it and now I am proceeding as you explain in your response.
      Thank you!
      Cheers,
      Eugenio
  • The topic ‘Winch that Changes Cable Length’ is closed to new replies.
