August 31, 2020 at 5:45 am
NithinNayak
SubscriberI went through many videos and blogs.Some say that the value should be minimum,while some say that we need to be on higher side.nPlease let me know the right range for element quality.nthank youn -
August 31, 2020 at 9:49 am
Keyur Kanade
Ansys EmployeeIf you are using Fluent, please use orthogonal quality. nYou should have min ortho quality as 0.1. Below this value, mesh is bad and needs improvement. n0 is worst and 1 is best. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn -
August 31, 2020 at 1:44 pm
NithinNayak
SubscriberThank you sir for your reply.nI am actually doing a structural analysis in ansys workbench 19.1,therefore I am using element quality criteria in mesh metric to check the feasibility of my mesh.nHence wanted to know the optimum value of the element quality.n -
September 2, 2020 at 11:20 am
Aniket
Forum ModeratorHave you checked the following:n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
- The topic ‘what is the optimum value of element quality in ansys workbench.’ is closed to new replies.
Ansys Innovation Space
1414
1241
1118
1015
