July 7, 2026 at 10:20 am
aniruddhabose96
SubscriberHi
I have a 3D pipe with DPM particles. I want to see the 'DPM Particles in Cell' using Voume rendering in the whole 3D space. But it is creating shapes similar to the mesh structures which is obstructing the visualisation of the variable. Can i remove the structures or the shapes from the contour plot and get a smooth contour? I have attached the picture below.
July 7, 2026 at 10:39 am
Essence
Ansys EmployeeHello,
Can you please show the mesh?
July 7, 2026 at 10:46 am
aniruddhabose96
SubscriberACtually i want to calculate the variable: N(cell)/A(cell)/N/A and plot it on the cross-section. But it is giving the above issue.
July 7, 2026 at 10:50 am
Essence
Ansys EmployeeYes, sure. But before that, can you please share some images of the mesh?
July 7, 2026 at 11:02 am
July 7, 2026 at 11:04 am
aniruddhabose96
SubscriberIts a O-grid mesh on the cross-section.
July 7, 2026 at 11:11 am
July 7, 2026 at 2:15 pm
Essence
Ansys EmployeeThanks for the images.
I see sudden cell jump between the inflation layers and core mesh. Please create smooth transition between the two. Also please note the refinement. I think the mesh is a bit coarse. Maybe you can conduct grid independence test?
Please try to increase the resolution. Did you import the .dat file or did you import some other file?
1343
