December 12, 2024 at 5:08 pmliliamzonBbp_participant
Hello, I am using Vista CPD in Ansys Workbench 2023R2 and right now I am facing a problem where when I generate the 3D volute it tends to have the dimensions and shape wrong. I even tried the default inputs in Vista CPD and the 3D generaton is still having weird volute dimensions.Â
Thank you in advance for those who helped.
Viewing 0 reply threads
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- error udf
- Cyclone (Stairmand) simulation using RSM
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Fluent fails with Intel MPI protocol on 2 nodes
- Encountering Error in Heterogeneous Surface Reaction
- Script Error
488
487
225
201
