July 17, 2025 at 1:50 am
jdo60
SubscriberHello,Â
I am working on a simulation to evaulate the lifespan of a semiconductor device, and I was wondering if it was possible to implement some sort of workflow to feed the results of my final simulation module back into the original module. I am using Interface Delamination with CZM to model the degredation of the semiconductor device, but I would like to see how the interface delamination affects the voltage and temperature of the semiconductor device.
In other words, is there some way to run 1 sub-step of the Electric -> Thermal -> Structrual -> CZM submodel, and then feed the CZM submodel solution back to Electric -> Thermal -> Structrual -> CZM submodel?Â
Ansys does not let me connect a static electric module to the CZM module.Â
Are there any other methods I can use to view the electric & thermal data after running the CZM submodel?Â
Workflow:
Regards,Â
Joshua
3492
1057
1051
966
942
