August 31, 2020 at 9:08 pm
vkr535
SubscriberHello Team,
I faced an issue while validating the DCB test for delamination using Ansys plane 182 plane stress option using VCCT.Â
-->The critical load as predicted by ansys doesn't seem to match with the expected values: It under-predicts the critical load for delamination.Â
-->Also, the initial slope of the force-deflection before the failure initiates also appears to be not matching.
I tried refining the mesh and using higher order but the issue still persists.Â
I have attached the input file: dcb.dat to reproduce this issue. Also attached is the image of the various simulated results.
The parameters of DCB are:
L=200Â Â Â Â Â Â Â Â Â Â Â !* length
dh=40Â Â Â Â Â Â Â Â Â Â Â Â !* total thickness
a0=100 ! pre-crack length
nel=200Â Â Â Â Â Â Â Â Â Â Â !* no.elements along length
neh=40Â Â Â Â Â Â Â Â Â Â Â Â !* no.elements along thick
emod=2.0e+05 ! E
thick=10 ! width
g1c=0.9628Â Â Â Â Â Â Â Â Â !* critical energy-release rate
pratio=0.3 ! *Proisson ratio
Please let me know your comments on observed results and suggestions. also, may i know if there is any validation problem to verify using plane stress option.
August 31, 2020 at 11:23 pmpeteroznewman
SubscriberWhere do the expected results come from?nYour plot legend says ref and in house code. What are those?nSeptember 1, 2020 at 12:18 amvkr535
SubscriberHello,nRef is taken from the paper: Wei-Jian Li, Qi-Zhi Zhu, Tao Ni,nA local strain-based implementation strategy for the extended peridynamic model with bond rotation, Computer Methods in Applied Mechanics and Engineering,nVolume 358, 2020, 112625,ISSN 0045-7825, https://doi.org/10.1016/j.cma.2019.112625.(http:/www.sciencedirect.com/science/article/pii/S0045782519305079)nIn house codes are ones we are trying to reproduce and match with Ansys results. i'm unable to attach the input file, so copied those contents here:finishn/clear,nostartn/prep7 ndis1=0.35 ! >=0.397435 0.4 (1125.94)ndis2=1.0nn1=1000nn2=1000nn3=10ndl=200           !* lengthndh=40            !* total thicknessna0=100nnel=200           !* no.elements along lengthnneh=40            !* no.elements along thickntoler=0.1e-5nemod=2.0e+05nthick=10ng1c=0.9628         !* critical energy-release rateng2c=0.0ng3c=0.0nEI=emod*0.5*dh*0.5*dh*0.5*dh*thick/12ndeno=emod*0.5*dh*0.5*dh*0.5*dhnPc=sqrt(g1c*deno/3.0)*(thick/(2*a0))nUc=2*sqrt(g1c/(3*deno))*a0*a0npratio=0.4nnet,1,182          !* 2d 4-node structural solid elementn!keyopt,1,1,2        !* enhance strain formulationnkeyopt,1,3,3        !* plane strainnet,2,182n!keyopt,2,1,2nkeyopt,2,3,3nnet,3,202          !* 2d 4-node cohesive zone elementn!keyopt,3,2,2       !* element free optionnkeyopt,3,3,3        !* plane strainnnR,1,thicknmp,ex,1,emodnmp,prxy,1,prationtb,cgcr,1,,3,linear    !* linear fracture criterionntbdata,1,g1c,g2c,g3cnn! fe modelnrectng,0,dl,0,dh/2      !* define areasnrectng,0,dl,0,-dh/2nlsel,s,line,,2,8,2     !* define line divisionnlesize,all,dh/nehnlsel,invenlesize,all, , ,nelnallsel,allntype,1           !* mesh area 2nmat,1nlocal,11,0,0,0,0nesys,11namesh,2ncsys,0ntype,2           !* mesh area 1nesys,11namesh,1nseltol,1e-06ncsys,0nnsel,s,loc,x,a0-toler,dlnnummrg,nodesneslnntype,3nmat,5nczmesh,,,1,y,0,      !* generate interface elementsnallsel,allnnsel,s,loc,x,dl      !* apply constraintsnd,all,allnnsel,allnn!nesel,s,ename,,202     !* select interface element toncm,cpath,elem       !* define crack-growth pathnnnslennsel,s,loc,x,a0nnsel,r,loc,y,0neslnncm,crack1,node      !* define crack-tip node componentnallselnfinishnn/solunresc,,nonenesel,s,type,,2nnsle,snnsel,r,loc,xnnsel,r,loc,y,dh/2    !* apply displacement loading on topnd,all,uy, dis1nnsel,allnesel,allnesel,s,type,,1nnsle,snnsel,r,loc,xnnsel,r,loc,y,-dh/2     !* apply displacement loading on bottomnd,all,uy,-dis1nnsel,allnesel,allnautots,onnnsubs,4,4,4ntime,1nncint,new,1      !* crack idncint,type,vcct    !* vcct calculationncint,ctnc,crack1   !* crack-tip node componentncint,norm,0,2nn! crack-growth simulation setncgrow,new,1     !* crack-growth setncgrow,cid,1     !* cint id for vcct calculationncgrow,cpath,cpath  !* crack pathncgrow,fcop,mtab,1  !* fracture criterionnCGROW,DTIME,2.0e-3nCGROW,DTMIN,2.0e-3nCGROW,DTMAX,2.0e-3ncgrow,fcra,1.02nnallsel,allnoutres,all,allnsolvenesel,s,type,,2nnsle,snnsel,r,loc,xnnsel,r,loc,y,dh/2    !* apply displacement loading on topnd,all,uy, dis2nnsel,allnesel,allnesel,s,type,,1nnsle,snnsel,r,loc,xnnsel,r,loc,y,-dh/2     !* apply displacement loading on bottomnd,all,uy,-dis2nnsel,allnesel,allntime,2nnsub,n1,n2,n3nsolvenfinishnn/post1nset,listn*GET,nmaxset, ACTIVE, 0, SET, NSETn*dim,imp_vol,,nmaxset,4,1n/com, *********************************n/com, Reference results:n/com, A local strain-based implementation strategy for the extended n/com, peridynamic model with bond rotation Comput. Methods Appl. Mech. Eng., 358 (2020), p. 112625n/com, *********************************nimp_vol(1,3,1)=0tnimp_vol(1,4,1)=0nimp_vol(2,3,1)=0.056544503tnimp_vol(2,4,1)=144nimp_vol(3,3,1)=0.136125654tnimp_vol(3,4,1)=350.7692308nimp_vol(4,3,1)=0.184293194tnimp_vol(4,4,1)=474.4615385nimp_vol(5,3,1)=0.262827225tnimp_vol(5,4,1)=679.3846154nimp_vol(6,3,1)=0.339267016tnimp_vol(6,4,1)=876.9230769nimp_vol(7,3,1)=0.396858639nimp_vol(7,4,1)=1026.461538nimp_vol(8,3,1)=0.436649215tnimp_vol(8,4,1)=1133.538462nimp_vol(9,3,1)=0.49947644tnimp_vol(9,4,1)=1028.307692nimp_vol(10,3,1)=0.62513089nimp_vol(10,4,1)=t919.3846154nimp_vol(11,3,1)=0.753926702nimp_vol(11,4,1)=t838.1538462nimp_vol(12,3,1)=0.823036649nimp_vol(12,4,1)=t803.0769231nimp_vol(13,3,1)=0.882722513tnimp_vol(13,4,1)=773.5384615nimp_vol(14,3,1)=0.956020942nimp_vol(14,4,1)=t744nimp_vol(15,3,1)=1.02408377nimp_vol(15,4,1)=t721.8461538n*cfopen,dcb_disp_force-ref,datn*vwrite,imp_vol(1,3,1), imp_vol(1,4,1)n(1x,2G20.
n*cfclosenfininn/post26nnsel,s,loc,y,dh/2nnsel,r,loc,x,0n*get,ntop,node,0,num,maxnnsel,allnnsol,2,ntop,u,y,uynrforce,3,ntop,f,y,fynprod,5,2, , ,dis_tip, , ,1.0nprod,6,3, , ,rf   , , ,1.0nxvar,5n/title,, dcb: reaction at top node verses prescribed displacementn/axlab,x,disp Uy (mm)n/axlab,y,reaction force Fy (N)nplvar,6n/com, export data to array parametersnvget,imp_vol(1,1,1),5nvget,imp_vol(1,2,1),6n*cfopen,dcb_disp_force,datn*vwrite,imp_vol(1,1,1), imp_vol(1,2,1)n(1x,4G20.
n*cfclosenfinish
Viewing 2 reply threads- The topic ‘VCCT delamination using plane182 with plane stress with thickness’ is closed to new replies.
6495
