UDF will not compile
    • salixb
      I was using ANSYS Fluent 2023 and recently had to move to the Fluent 2025 R2. I had no problem using the UDF with the previous version of the software, but now am unable to compile/build the UDF.
      Try with the built in compiler. I can't remember any significant macro changes, but that would likely show up in the build error messages too.
    • salixb
      Hi Rob,
      I tried with the built in compilier and get the following error: lld-link: error: undefined symbol. I am just confused as I had no problem with the .c file with the 2023 version of Fluent.
      Thanks!
      All the files are in the same folder, and you're running Fluent standalone? Please can you post the actual error with all the text that's generated? Fluent's messages are usually quite long, and it's common to need to see the whole lot to diagnose.
    • salixb
      All the files are in the same folder. I am running Fluent from workbench.
      Here is the error:
      Copyright 1987-2025 ANSYS, Inc. All Rights Reserved.
      Compiler and linker: Clang (builtin)
      Compiler path: "C:\PROGRA~1\ANSYSI~1\v252\fluent"\ntbin\clang\bin\clang-cl
      Linker path: "C:\PROGRA~1\ANSYSI~1\v252\fluent"\ntbin\clang\bin\lld-link
      C sources: ['force_liu.c']
      lld-link: error: undefined symbol: P_DIAM
      >>> referenced by force_liu.obj:(LiuDrag)
      >>> referenced by force_liu.obj:(wangdrag)
      >>> referenced by force_liu.obj:(myBrownian)
      lld-link: error: undefined symbol: P_RHO
      lld-link: error: undefined symbol: P_DT
      lld-link: error: undefined symbol: P_TIME
      scons: *** [libudf.dll] Error 1
      Done.
      P_DIAM and not PP_ or TP_ ?
    • salixb
      This UDF was written in 2004, to define spherical particle drag, like I've said I've had no issues until switching to the most recent version of Fluent. Has the way to reference the fluent particle diameter in the UDF changed? When I tried to go through the manual I didn't see any specifics about this.
Viewing 6 reply threads
