3D Design
3D Design
Turning off “Parameters
    • metalock
      I created a model of a bolt by revolving  a surface around the axis of the bolt.  Now when I go to change the diameter of the shank of the bolt or the threaded region a "P" pops up next to the diameter that I wish to change.  How do I get rid of the P.
      Also, I am trying to create a thread on the end of this bolt.  What I want is 1 3/4" x 8 Tpi.  I get an error message regarding some offset surface.  Where is that coming from?
      Thanks for the help.
      Tommy Breaux
    • Devendra Badgujar
      Hi Tommy Breaux
      Can you please share the model, it will help us understand the problem better.
      Regards.
    • Devendra Badgujar
      Hi Tommy Breaux
      Please can you update here to assist you further with this query?
      Regards.
  • The topic ‘Turning off “Parameters’ is closed to new replies.
