Topics relate to Mechanical Enterprise, Motion, Additive Print and more
Solver Pivot warning detected in the UY degree of freedom. Help
    • Yazun
      Bbp_participant
      nThe vanes must be attached to the shaft, so you want Bonded Contact instead of frictionless contact. If the whole assembly was solid meshed, then it would solve without error.n
    • Yazun
      Thank you for your comment I did this and it worked n
  • The topic ‘Solver Pivot warning detected in the UY degree of freedom. Help’ is closed to new replies.
