Electronics
Electronics
Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
SIWAVE software crashes
    • wen bo
      I'm running a DC IR Drop simulation on a layout. But, after the DC IR drop simulation is complete, check the result (plot current/voltage). The SIWAVE software crashes.
      This does not happen when the same operation is performed on other layouts.What is the problem with the layout that leads to this situation?
    • Sriparna
      Hi Wen,
      Thanks for asking this in Ansys Learning Forum.
      Can you please try to simulate the same layout in some other higher configuration PC and check the result there? This might solve your issue.
  • The topic ‘SIWAVE software crashes’ is closed to new replies.
