Electronics
Electronics
Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
SIWave parallel plate capacitor simulation
    • Dracarys99
      Reading on the internet, I see that it is possible to simulate a PCB modelling it as a large parallel plate capacitor and obtain the Impedance vs Frequency plots, where we can see the "spikes" towards the left side of the graph, something like this:-
    • manny
      Hi Dracarys99,nInstead of SIwave, Q3D Extractor is an appropriate choice for parallel plate capacitor simulation. Ansys Q3D Extractor can extract RLCG parameters after performing 2D and 3D quasi-static electromagnetic field simulations. Good luck!nBest,nManny.n
    • Dracarys99
      nI tried HFSS and Q3D. In both cases, I made a 50mmx50mm parallel plate capacitor with 2mm of FR4 dielectric in between. I get the capacitance value correct, but I think I have to use the DrivenModal solution type in HFSS for getting the impedance vs freqeuncy plot like I mentioned above. Also, I can't get how to assign (and where) a lumped port, I think I have to use this as well. nIt will helpful if you outline the process of getting the graph I need (as I mentioned above) in Q3D (or in HFSS).nThank you.n
    • Dracarys99
      I want to get a result like this n
    • Dracarys99
      n
    • Dracarys99
      For this problem I am getting the correct capacitance but the impedance vs frequency graph that I plot has an exponentially decaying to zero curve, nothing like the graph I need (posted above). What am I doing wrong?n
Viewing 5 reply threads
  • The topic ‘SIWave parallel plate capacitor simulation’ is closed to new replies.
