November 25, 2025 at 10:18 pm
parsaary
SubscriberHi,
I recently asked a question about how to speed up a slow rocky-fluent simulation (https://innovationspace.ansys.com/forum/forums/topic/ways-to-accelerate-a-cfd-dem-simulation/?template=rocky)
In response, I was told that "if the bottleneck is on the Fluent side, you can allocate more CPU cores and even run it in distributed mode. If the bottleneck is on the Rocky side, you can allocate more GPUs to increase performance"Â
I think the bottleneck is in the fluent portion, so I'd like to use 2 nodes to run fluent in distributed parallel.
Coud you please check my set-up and tell me what's wrong? Setup details and error are all shown below. Thanks.
Best regards,
Parsa
Set-up:
I am running the sim on a remote HPC using 2 nodes that each have 4 gpu's and 24 cpu's. Since rocky can't do multinode, i am assigning it to only one of the nodes, such that it uses 4 gpu's, as well as 4 cpu's for miscellaneous tasks such as data transfer. The other 20 cpu's of that node as well as all 20 (or 24?) of cpu's from the other node are assigned to fluent (distributed parallel).
Gui:
.sh file:
#!/bin/bash
#SBATCH --account=ABC-gpu      # GPU account
#SBATCH --job-name=distpl   # Job name
#SBATCH --time=00-12:00Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â # Time limit dd-hh:mm
#SBATCH --nodes=2Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â # Request 2 compute nodes
#SBATCH --ntasks-per-node=24Â Â Â Â Â Â Â Â Â Â Â Â # 24 CPU cores per node
#SBATCH --cpus-per-task=1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â # Do not change
#SBATCH --mem-per-cpu=7GÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â # Memory per CPU
#SBATCH --gpus-per-node=4Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â # 4 GPUs per GPU node
#SBATCH --output=myrockylog.out         # Output file
# Cleanup old Rocky/Fluent crash files
rm -f cleanup* core*
# Environment Setup
export PATH=ABC
export LD_LIBRARY_PATH=ABC
export ANSYSLMD_LICENSE_FILE=ABC
export ANSYSLI_SERVERS=ABC
export ANSYS232_DIR=ABC
export AWP_ROOT232=ABC
export ANSYSLIC_DIR=ABC
export LC_ALL=C
# SLURM → Fluent Node File
scontrol show hostnames $SLURM_JOB_NODELIST > hosts.txt
export SLURM_NODEFILE=hosts.txt
echo "==== Rocky/Fluent Nodefile ===="
cat hosts.txt
echo "==============================="
# CPU count
NCORES=$((SLURM_NTASKS * SLURM_CPUS_PER_TASK))
echo "NCORES = $NCORES"
# Force Rocky to run ONLY on GPU node #1
GPU_NODE=$(scontrol show hostnames $SLURM_JOB_NODELIST | head -n 1)
echo "Running ROCKY on GPU node: $GPU_NODE"
srun --nodes=1 --nodelist=$GPU_NODE --gres=gpu:4 \
   Rocky --simulate "RProcky.rocky" --resume=1 \
   --use-gpu=1 \
   --gpu-num=0 --gpu-num=1 --gpu-num=2 --gpu-num=3 \
   --ncpus=4
Output file:
==== Rocky/Fluent Nodefile ====se355se387===============================NCORES = 48Running ROCKY on GPU node: se355Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...Looking for libstdc++ ...System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled:System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29System: - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /lib64/libstdc++.so.6 - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing bundled libstdc++Choosing bundled libstdc++System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++Looking for libstdc++ ...Looking for libstdc++ ...System: - version: 3.4.29System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6 - path: /lib64/libstdc++.so.6System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂChoosing bundled libstdc++Bundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing bundled libstdc++Choosing system libstdc++System:Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++ - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing bundled libstdc++Choosing bundled libstdc++Choosing bundled libstdc++System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing system libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂSystem: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing system libstdc++Choosing bundled libstdc++Choosing system libstdc++System: - version: 3.4.29 - path: /lib64/libstdc++.so.6ÂBundled: - version: 3.4.29 - path: /ABC/ANSYS2023_Fluent/v232/rocky/bin/gcc-libs/libstdc++.so.6ÂChoosing bundled libstdc++Choosing system libstdc++Installing backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successInstalling backtrace handlers...successjson:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicejson:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}lsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}lsblk: wwroot: not a block devicejson:{"status": "SIMULATING"}json:{"status": "SIMULATING"}json:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}QSocketNotifier: Can only be used with threads started with QThreadjson:{"status": "SIMULATING"}lsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicelsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicelsblk: wwroot: not a block devicejson:{"status": "SIMULATING"}json:{"status": "SIMULATING", "message": "RProcky.rocky"}QSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicelsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicejson:{"status": "SIMULATING", "message": "RProcky.rocky"}lsblk: wwroot: not a block devicelsblk: wwroot: not a block devicelsblk: wwroot: not a block devicelsblk: wwroot: not a block devicelsblk: wwroot: not a block devicelsblk: wwroot: not a block devicelsblk: wwroot: not a block deviceQSocketNotifier: Can only be used with threads started with QThreadlsblk: wwroot: not a block devicejson:{"status": "SIMULATING", "message": "RProcky.rocky *"}lsblk: wwroot: not a block deviceTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/vertical/poolprojecthandler.py", line 143, in Opensrun: error: se355: task 11: Exited with exit code 1 File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/simulation/batch_simulation.py", line 389, in _Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 259, in Loadsrun: Terminating StepId=6818447.0 File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 242, in ExecLoad File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 297, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1511, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1332, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 502, in _HandleBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/io/rocky_io_backward_compatibility.py", line 783, in FluentTwoWayBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 593, in HasInvalidMappingIntefaceIds File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 579, in GetAvailableMappingInterfaces File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 480, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_coupled_wrapper.py", line 529, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 50, in GetCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 111, in _ReadCaseConfigCache File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 299, in load File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 354, in loads File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 339, in decode File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 357, in raw_decodejson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)Traceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/vertical/poolprojecthandler.py", line 143, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/simulation/batch_simulation.py", line 389, in _Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 259, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 242, in ExecLoad File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 297, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1511, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1332, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 502, in _HandleBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/io/rocky_io_backward_compatibility.py", line 783, in FluentTwoWayBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 593, in HasInvalidMappingIntefaceIds File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 579, in GetAvailableMappingInterfaces File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 480, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_coupled_wrapper.py", line 529, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 50, in GetCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 111, in _ReadCaseConfigCache File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 299, in load File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 354, in loads File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 339, in decode File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 357, in raw_decodejson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)ÂDuring handling of the above exception, another exception occurred:ÂTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 160, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/vertical/poolprojecthandler.py", line 154, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/poolcontent.py", line 132, in EngageModelInstances File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/poolcontent.py", line 144, in _Engage File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/model/study_model_builder.py", line 421, in Engage File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/subject/_pool.py", line 400, in __getitem__KeyError: 'project.study_00001.materials_interaction_container'ÂThe above exception was the direct cause of the following exception:ÂTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 279, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/ben10/source/python/ben10/foundation/reraise.py", line 9, in ReraiseKeyError: 'Unable to open project file.'ÂDuring handling of the above exception, another exception occurred:ÂTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 284, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/subject/_pool.py", line 491, in EndModify File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/subject/_pool.py", line 125, in __call__ File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/site-packages/oop_ext/foundation/callback/_callback.py", line 303, in __call__ File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/parametric_vars/parametric_vars_listener.py", line 77, in _OnCompleteAddParametricVarsSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/parametric_vars/parametric_vars.py", line 572, in GetOutputVariableProcessesTypeError: 'NoneType' object is not subscriptableTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/vertical/poolprojecthandler.py", line 143, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/simulation/batch_simulation.py", line 389, in _Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 259, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/iomapping.py", line 242, in ExecLoad File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 297, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1511, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1330, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 809, in LoadObjectAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1288, in Load File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1342, in LoadSubject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 1332, in LoadAttributes File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/io/mapped/_mapped_io.py", line 502, in _HandleBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/io/rocky_io_backward_compatibility.py", line 783, in FluentTwoWayBackwardCompatibility File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 593, in HasInvalidMappingIntefaceIds File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 579, in GetAvailableMappingInterfaces File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/process/cfd/fluent/fluent_two_way_coupling_process.py", line 480, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_coupled_wrapper.py", line 529, in GetFluentCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 50, in GetCaseConfig File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky/rocky30coupling/source/python/rocky30coupling/fluent/fluent_two_way_validator_cached.py", line 111, in _ReadCaseConfigCache File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 299, in load File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/__init__.py", line 354, in loads File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 339, in decode File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/json/decoder.py", line 357, in raw_decodejson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)ÂDuring handling of the above exception, another exception occurred:ÂTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 160, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/vertical/poolprojecthandler.py", line 154, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/poolcontent.py", line 132, in EngageModelInstances File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/pool/poolcontent.py", line 144, in _Engage File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/model/study_model_builder.py", line 421, in Engage File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/coilib50/source/python/coilib50/subject/_pool.py", line 400, in __getitem__KeyError: 'project.study_00001.materials_interaction_container'ÂThe above exception was the direct cause of the following exception:ÂTraceback (most recent call last): File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/scripting/base_scripting.py", line 97, in ExecScripting File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/kraken20/source/python/kraken20/plugins/project_manager/_project_manager.py", line 22, in ActualOpen File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_manager.py", line 29, in ActualOpen File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/project_manager/_project_manager.py", line 428, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/project_manager/_project_manager.py", line 695, in DoOpen File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/project_manager/_project_manager.py", line 439, in DoOpen File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/plugins/project/project_handler.py", line 553, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 480, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/undo_redo/_undo_redo_helpers.py", line 86, in CleanAndExecuteWithoutCmdHis File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_handler.py", line 279, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/ben10/source/python/ben10/foundation/reraise.py", line 9, in ReraiseKeyError: 'Unable to open project file.'ÂThe above exception was the direct cause of the following exception:ÂTraceback (most recent call last): File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/site-packages/cx_Freeze/initscripts/__startup__.py", line 14, in run File "/home/jenkins/Work/miniconda/envs/_rocky30-freeze-linux64-py36-v3/lib/python3.6/site-packages/cx_Freeze/initscripts/Console.py", line 26, in run File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/main.py", line 13, in File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/frozen_utils.py", line 70, in RockyBasedAppMain File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/basic_application/main.py", line 264, in Main File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/basic_application/main.py", line 426, in _Main File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/rocky_application_setup.py", line 49, in CallMain File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/batch_mode.py", line 25, in MainBatch File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/rocky30/source/python/rocky30/batch_mode.py", line 55, in _RunInBatchMode File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10core/source/python/plugins10core/pluginmanager.py", line 1109, in Main File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10core/source/python/plugins10core/pluginmanager.py", line 708, in Main File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/uiapplication/uiapplication.py", line 370, in Main File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/uiapplication/uiapplication.py", line 388, in BeforeProcessEvents File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/command_line/command_line_open.py", line 212, in HandleCommandLine File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/command_line/command_line_open.py", line 143, in HandleOpenProject File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/command_line/command_line_open.py", line 125, in _OpenProjectFile File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/project_handler/_project_manager.py", line 46, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/petroapp10/source/python/petroapp10/plugins/scripting/_petroapp10_scripting.py", line 100, in Open File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/etk/plugins10/source/python/plugins10/plugins/scripting/base_scripting.py", line 127, in ExecScripting File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.2.0-ansys-newlinux/ben10/source/python/ben10/foundation/reraise.py", line 9, in ReraiseKeyError: "Error when executing scripting command: Open. Arguments: {'filename': 'RProcky.rocky'}"[2025-11-21T23:55:31.264] error: *** STEP 6818447.0 ON se355 CANCELLED AT 2025-11-21T23:55:31 DUE TO TASK FAILURE ***srun: error: se355: tasks 0-9,12-23: Terminatedsrun: error: se355: task 10: Terminatedsrun: Force Terminated StepId=6818447.0Â
- affinity not set
4392
1494
1375
1209
