Topics relate to Mechanical Enterprise, Motion, Additive Print and more
Reinforced structure
    • BruceYuan
      I am trying to do an FEA analysis for a rebar-reinforced FRP plate. My geometry consisting of the plate and other parts is assembled using Solidworks. After importing the geometry, Ansys does not allow me to setup an interaction contact between the rebars and the FRP plate. Does this mean that I have to build the full geometry in SpaceClaim.
      Thanks a lot!
    • Govindan Nagappan
      nBody interaction is available only for Explicit dynamic analysis. nSee help section:n https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/wb_sim/ds_Contact.htmlnIf you are doing any other type of analysis, you will have to use other connection options such as contacts , joints etcn
    • BruceYuan
      nThanks for the reply. If I want to analyze this model using static structural analysis, should I use Bond contact type for and rebars and FRP?.
    • BruceYuan
      nnI have also tried to remove the rebars in my Solidworks model and then import the model into DesignMolder to create line bodys of rebars. When I setup my model in static structural analysis, I cannot create a manual contact between the line bodies (rebars) and FRP blocks. Could you please explain it to me?.Thanks!!n
    • Govindan Nagappan
      nSee description of different contact types (bonded, no separation etc) here:nYou can select the appropriate contact type as needed for your simulationnYou should be able to define contact between edge(beam) and solid. Set the contact formulation to MPC for beam to solid contact. See help section:nn
Viewing 4 reply threads
  • The topic ‘Reinforced structure’ is closed to new replies.
