October 8, 2024 at 9:40 pmunnosSubscriber
How does the "reduce facets" operation in Spaceclaim work?
Are facets simply deleted on a stochastic basis or multiple facets merged into larger ones?
What is the underlying mathematical principle for this? I could not find an explanation in the Ansys documentation.
October 9, 2024 at 12:43 pmAtharv JoshiForum Moderator
Hello Unnos,
You can check the help doucmentation Reducing the Number of Facets (ansys.com)
The model or selection is re-faceted with fewer triangles based on the Triangle reduction and Maximum deviation specified.
Regards
Atharv
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
591
544
524
366
