Topics related to Fluent, CFX, Turbogrid and more
Question about copying a single-passage result to the full-passage
    • weij2018
      Hello, everyone. I am doing a fluid-thermal-solid interaction project, linking the CFX model to the static structural model. I compute the solid body temperature in CFX by conjugate-heat transfer, and I import the body temperature to the solid in the static structural model to calculate thermal stress and deformation.
      And the problem is that I compute a single passage result; for example, I calculate the temperature of a turbine with 21 blades, and I want the whole turbine's body temperature so I can obtain the entire turbine's thermal stress and deformation
      . Can anybody please help me copy the single-passage result of the CFX to the whole passage? Thank you so much!
    • Surya Deb
      Can you export the thermal data from CFX and then suitably map it on the full domain in Static Structural?
      SD
  • The topic ‘Question about copying a single-passage result to the full-passage’ is closed to new replies.
