Post CFD for ANSYS fluent in 19.2 version
    • abiase
      1. How to make plots of contours and particle tracks/pathlines on the same figure in post CFD? (Generally, how to use post CFD)
      2. What is the difference between post CFD from the workbench page vs. the post cfd in the solutions section of ansys fluent?
    • Keyur Kanade
      question is not clear to me.
      fluent has post processing options in 'postprocessing' tab or 'results' tab in model tree.
      if you want to have contours and tracks in same window in fluent then please create contours first. then create tracks.
      then in model tree please use right click on say contours and use 'add to graphics' option.
      CFD-Post is different tool which is meant for post processing.
      if you want it in cfdpost then please create contours and tracks. then just make them visible from model tree.
      hope this helps.
      you can also check following videos.
      if this resolves your issue, please mark this as 'is solution' to help others on forum.
      https://www.youtube.com/watch?v=Mv7w2PBkf8M
      https://www.youtube.com/watch?v=7gmS8_Nwq5c
  • The topic ‘Post CFD for ANSYS fluent in 19.2 version’ is closed to new replies.
