TAGGED: 3d-mesh, 3d-meshing, air, air-flow, air-movement, airflow, Ansys-Mesh, ansys-meshing, ansys-meshing-software, ansysmesher, assembly-meshing, boundaries, boundary, boundary-condition, boundary-conditions, boundry-condition, face-meshing, Fluent-boundary-conditions, fluent-mesh, fluent-meshing, fluentmesh, fluentmeshing, inlet, inlet-boundary-condition, Inlet-boundary-conditions, mesh, mesh-a-cylinder, Mesh-Ansys-Fluent, meshing, modeling-and-meshing, outlet, outlet-boundary-condition, wall, wall-bc, wall-boundary-condition, wall-bounded-flow
July 6, 2026 at 6:21 pm
cam652
SubscriberI'm trying to make an air flow simulation with this model of a gliding arc plasmatron. I'm new to Ansys, and I've only made meshes for fluid domains. How do I make the boundary conditions (inlets, outlets, etc.) for this model? I've attached a series of images for different views; some have parts hidden to show other parts inside.
July 6, 2026 at 7:13 pm
Essence
Ansys EmployeeHello,
Have you generated the mesh? If not, then I would recommend you to first import the geometry in Discovery/SpaceClaim, create the named selections and then import the model in Meshing.
July 9, 2026 at 6:17 pm
cam652
SubscriberYes, I have generated the mesh. All of the screenshots were taken in the meshing software.
1343
