July 9, 2024 at 9:07 pmWenqin SongSubscriber
Hello all,
I am trying to set up the workflow in Optislang which involves the Maxwell simulation and a Matlab script. The Matlab script is used to perform fft on the simulation report generated by Maxwell (.csv file). I have added the excel node for the Maxwell output report, for some reason, Matlab is giving me this error message which I have no idea what it is. My Matlab code can be run without any problems, (I have tested in the test run). What can be done to solve this problem here?
August 2, 2024 at 11:40 amVeit BayerAnsys Employee
Dear Wenqin Song,
from MATLAB side it looks like a warning only, but it appears that optiSLang interprets this as an error. I don't know why, maybe because of an exit code. I suggest to modify the MATLAB script according to the text in the warning message.
Best regards,
Veit
- The topic ‘Matlab integration in Optislang’ is closed to new replies.
- Multi-Objective Shape Optimisation of Tesla Valve
- Creating Fluent Web Apps using optiSLang 2021R2.mp4
- Adjoint Method for Optimising Diodicity of Tesla Valve
- How to access “OSL_DESIGN_DIR” Environmental variable?
- Output parameter as an exported text data file
- Setup Optimetrics at HFSS 3D Layout Design
- Response constraint not allowing structural optimization to solve.
- Material parameter optimization
- DP0 The Design of Experiments component in Response Surface could not be updated
1281
591
543
524
366
