June 13, 2020 at 7:09 pm
Andreyteston
SubscriberHello, members.
I would like to use this relationship for the concrete on the confinement effect.
I have already tried these models:Â
Multilinear Kinematic Hardening Constants (TB,KINH) and Multilinear Isotropic Hardening Constants (TB,MISO), however, in these models is not a possible constitutive relationship stress-strain with negative slopes.
Nonlinear Isotropic Hardening Constants (TB,NLISO), however, in the models is not possible to add the constitutive relationship stress-strain.
Actually, I have been tried Multilinear Elastic Constants (TB,MELAS), on the other hand, reading about this model, I have found in ANSYS help: "This behavior, unlike the other options, is conservative (path-independent). The plastic strain for this option should be interpretedas a "pseudo plastic strain" since it returns to zero when the material is unloaded".
1. Does this mean that material behavior will be linear even that my analysis will be non-linear?
2. Is it possible to put my constitutive relationship stress-strain using Experimental Data (TB,EXPE)?
I would like to obtain help.
Regards.
June 18, 2020 at 3:14 pm
Wenlong
Ansys EmployeeHi Ândrey,
Sorry about the late reply.Â
I don't think hardening laws should be used for your case because as you mentioned, we cannot define negative slopes in these models. To define your stress-strain behavior you will need other material models.Â
Microplane material model can capture damage (which is responsible for softening behavior) and has been applied for concrete modeling. It could be a candidate for your simulation. You can find more information here:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/ans_mat/microplane.html?q=microplane
Here is an example of using Microplane material in reinforced concrete joint:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/ans_tec/tecreinfconcresults.html
There are many material constants you will need to calibrate from your test data. Good luck!
Wenlong
June 18, 2020 at 4:42 pm
Andreyteston
SubscriberHi, Wenlong!
No problems with the time, I really would like to thank you for your contribution.Â
Knowing that hardening laws represent positive inclines in the stress-strain behavior and evidently not support negative slopes, based on your information, I won't use these material models.
So, I will use the Microplane material model. Based on your information, I will mark this topic with the solution.Â
Thank you again for the help and for your wish for good luck.
Regards.
ÂndreyÂ
- The topic ‘Material model to input the stress-strain relationship for concrete with a negative slope’ is closed to new replies.
6495
