August 3, 2023 at 4:29 amSahaSubscriber
I have set up a dual source FDTD sim and I need to calculate each source's power in analysis. But for unknown reason the command "sourcepower" is not working for any particular source in the analysis script. It's working in command prompt though. Not sure what's wrong here.
Also, is there other way of calculating the source power manually? I want to calculate it in analysis group rather than seperately because later these results will be collected as part of parameter sweep sim. -
August 3, 2023 at 6:45 amSahaSubscriber
August 3, 2023 at 5:51 pm
- The topic ‘Issue in using “sourcepower” command in multi-source simulation’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Absorption cross-section of AuNR excited by prism-based TIR
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
599
591
565
366
