Is it possible to get last iteration value in CFX
    • danielxu1
      Hello, nMy boundary condition needs to be changed based on the value of last iteration. Is it possible to get last iteration value in CFX? In Fluent I can store it as a global variable and read it again by using UDF, but I don't know how to do it in CFX. Thank you in advance!n
    • Surya Deb
      Hello, nIt is not very clear as to what value you are referring to. Do you mean a certain residual value for your last iteration, like continuity ?nAlso you could make use of the result file (.res) to use as an initial condition for another case/run.nRegards,nSuryan
  • The topic ‘Is it possible to get last iteration value in CFX’ is closed to new replies.
