Topics relate to Fluent, CFX, Turbogrid and more
Inlet profile at an angle to inlet
    • namrata mishra
      Hii
      I am using a UDF at the inlet to simulate wind flow inside the domain. Now, I need this wind profile at 30 degrees to the inlet. how can i specify angle in my boundary conditions without changing the udf. I am attaching some screenshots for reference.
      Also, I chose velocity specification method normal to boundary. If I change it to magnitude and direction, I cant clearly understand what to specify in X, Y and Z directions.
    • SRP
      You need to make changes in the UDF itself to make flow at 30 degree or make an expression at the inlet corresponding to 30 degree.
      Thank you.
    • namrata mishra
      Ok. Can you please suggest me what changes do I need to make . My udf code is as follows:
      #include "udf.h"
      #define UREF 4.7/* ref. speed 3.0 m/s */
      #define CMU 0.09
      #define H 12
      #define u_star 0.52
      #define delta 36
      #define p_constant 0.4
      DEFINE_PROFILE(velocity_profile, thread, position)
      float x[ND_ND];
      float y;
      float u_in;
              face_t f;
      begin_f_loop(f, thread)
      F_CENTROID(x,f,thread);
      y=x[1];
      u_in = UREF*pow(y/H,0.3);
      F_PROFILE(f,thread,position) = u_in;
      end_f_loop(f, thread)
      /*  profile for kinetic energy  */
      DEFINE_PROFILE(k_profile, thread, position)
      float x[ND_ND];
        face_t f;
              float y;
              float k;
            y=x[1];
                      k=(u_star*u_star/pow(CMU,0.5))*(1-(y/delta));
            F_PROFILE(f,thread,position)=k;
      /* profile for dissipation rate  */
      DEFINE_PROFILE(dissip_profile, thread, position)
        float x[ND_ND];
        face_t f;
      float y;
              float eps;
      y=x[1];
            eps=(pow(u_star,3)/(p_constant*y))*(1-(y/delta));
                      F_PROFILE(f,thread,position)=eps;
        end_f_loop(f,thread)
      Change to "components" rather than magnitude normal to boundary. You then need two DEFINE_PROFILE(velocity_profile, thread, position) blocks for the two components. Hint, don't call them both "velocity_profile".
  • The topic ‘Inlet profile at an angle to inlet’ is closed to new replies.
