Topics relate to Fluent, CFX, Turbogrid and more
Increasing number of iterations on HPC through TUI commands in journal file.
    • Ramesh Chandra Mishra
      Hi
      I have run my simulations in HPC for 4000 iterations and obtained .dat file for the same. Now I wish to continue the simulations for another 6000 iterations without repeating those 4000 iterations. What command should I add to the journal file?
    • Federico Alzamora Previtali
      you can use solve/iterate 6000.
      If your Fluent session has closed, you can load the case and data files in a journal using file/read-case-data [casefilename.cas] [datafilename.dat]
  • The topic ‘Increasing number of iterations on HPC through TUI commands in journal file.’ is closed to new replies.
