Topics relate to Fluent, CFX, Turbogrid and more
In Fluent, is there a way to change the console text color and size?
    • Timothy Braun
      I think I must have set something up wrong. I have a low-contrast color in my console. My text looks something like this on a white background. Is there a way to customize the console foreground/background combination and even to set up the default text height (lower priority)? I cant find any setting to change just the console in the GUI or the normal TUI menus. Is it a scheme command (rp or cx var)?
    • CFD_Friend
      Hi Timothy,
      Try changing the theme, this can be found in File ~> Preferences ~> Appearance  ~> Color Theme. Dark themes are available and can give excellent contrast to the console. Try setting it to your choice and then click okay. And then reopen the fluent session. This can resolve the issue.
      • Timothy Braun
        Thank you - it was the restarting of the session that I overlooked after switching the color theme ...despite the very clear message box that told me to do so!
  • The topic ‘In Fluent, is there a way to change the console text color and size?’ is closed to new replies.
