Implementing anisotropic creep properties in workbench
    • Andeshpande
      I am trying to figure out how to input anisotropic creep properties in workbench simulation. While searching a bit, I read that anisotropic creep can be modeled as a combination of Hill and creep property inputs.
      Any thoughts how to implement this in workbench?
      Thanks in advance.
    • Sandeep Medikonda
      Hi, Please remove any sharcnet links from the posts and use ANSYS Help. If you don't know how to get help, please see here ( 1 & 2)
      Regarding your question. Yes, you can model the Hill Criterion using anisotropic creep. Please see here.
      Please take a moment to review the guidelines to the student community.
      Sandeep
    • Ashish Khemka
      Just a suggestion- you can try a user defined material to have more flexibility in defining anisotropic flow rule.
      Ashish Khemka
  • The topic ‘Implementing anisotropic creep properties in workbench’ is closed to new replies.
