November 15, 2024 at 7:53 amjackhc0609Subscriber
"I am using Fluent Meshing to model and simulate a heat exchanger. I represented the solid wall of the heat exchanger with a thin wall using a single face, and I also imported the file for the heat exchanger shell. My idea is to use the thin wall to split the heat exchanger shell, and then use the intersect operation to create two fluid domains. In this way, the two fluid domains created would share common nodes. However, my requirement is to generate two fluid domains where the heat exchange surfaces do not share nodes. How should I proceed with this? I tried clicking on 'Non Conformal' as shown in the picture, but I don’t know what to set up afterward, and failed non-conformal.(The aim is to use the interface,often my model boundary layers are hard to generate!)
November 15, 2024 at 8:22 amjackhc0609Subscriber
I wanna use the intertfaces to obtain conjugate heat transfer.
November 15, 2024 at 10:12 amRobForum Moderator
We'd usually mesh that as conformal and set the zones as fluid/solid depending on what they were.
November 15, 2024 at 10:19 amjackhc0609Subscriber
But how could I mesh the two conformal fluid volume into non-conformal mesh as the figure shows in the left red rectabngle(non-conformal)! I am really hard to generate the oundary layers in my model. I eagerly to want the interfaces !Thanks!
November 15, 2024 at 11:35 amRobForum Moderator
Why do you need an interface? Please read Fluent's boundary types carefully: interface isn't the same as interior which isn't the same as a wall.
November 15, 2024 at 11:55 amjackhc0609Subscriber
But could the nonconformal button in the figure works?
November 15, 2024 at 11:57 amRobForum Moderator
That's the quad-tet transition. Which workflow are you using?
November 15, 2024 at 12:14 pmjackhc0609Subscriber
outlineview
November 15, 2024 at 1:10 pmRobForum Moderator
Have a look at the tutorials and Watertight workflow.
November 15, 2024 at 1:32 pm
November 15, 2024 at 1:37 pmRobForum Moderator
Do the tutorials. https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?lang=en You can make nonconformal meshes that way, but I think you may want to rethink that approach.
November 15, 2024 at 1:42 pm
November 15, 2024 at 1:59 pmRobForum Moderator
You could try Fluent, as that's where the Meshing tool is.
November 15, 2024 at 2:00 pmjackhc0609Subscriber
could you provide more information about how the watertight mode mesh the non-conformal mesh?
November 15, 2024 at 2:03 pmRobForum Moderator
There is a reason for there being tutorials, and a User's Guide. You've still not explained why you need nonconformal over a conformal mesh.
November 15, 2024 at 2:06 pmjackhc0609Subscriber
Due to the model is hard to generate boundary layers (fixed the mesh intersetion and proxiemity by move the node may lead to sharp edges which lead to the difficulty for generating the boundary layer),So i prefer to non-conformal interface mode .
- Non-Intersected faces found for matching interface periodic-walls
- error udf
- Cyclone (Stairmand) simulation using RSM
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Fluent fails with Intel MPI protocol on 2 nodes
- Encountering Error in Heterogeneous Surface Reaction
- Script Error
1156
488
486
225
201
