January 4, 2024 at 7:00 am
coleen.dizon
SubscriberI attended the Achieve Compact and Integrated Power Supply Designs in Consumer Electronics webinar. I'm very interested in the Litz material composition introduced there. I would like to know more about this feature and how to use it. Anyone have tutorial and lecture regarding this feature up to using it for ROM and post-porcessing losses? The write up for this is very short in ANSYS help.
January 4, 2024 at 10:46 pm
DELI
Ansys EmployeeHi Coleen, here is a technote shared on Ansys.com about Litz wire modeling, hope it helps. https://www.ansys.com/blog/using-litz-wire-in-maxwell-2d-and-3d-simulations
- The topic ‘How to use Litz material composition?’ is closed to new replies.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
1494
1376
1209
