How to simulate a simple air jet and apply external excitations to control it.
    • Kauê Castro
      Greetings.. Im studying forms of controlling fluid jets using periodic excitation as in the blowing and sucking of a subwoofer of some sorts. I need help on two regards:
      Firstly, I am having trouble simulating the simple case of only the jet, that is, the residuals are not decreasing after a given amount of iterations, would the problem be my mesh?
      And, I don't have a clue on how to introduce an external periodic excitation as I said. Is there any feature that enables me to simulate a subwoofer, or vibrate the flow in a given part of the inlet boundary?
      What sort of frequency are you going to excite the jet at?  Without seeing the model I can't comment on convergence, so please post pictures. Contours of velocity & velocity vectors would be a good starting point. I assume you're running transient?
      Have a look for fluidic switches on Google.
      /forum/forums/topic/how-to-input-a-periodic-excitation-to-a-flow-or-jet/
  • The topic ‘How to simulate a simple air jet and apply external excitations to control it.’ is closed to new replies.
