Topics relate to Fluent, CFX, Turbogrid and more
How to perform remeshing for 3D boundary layer elements
    • Rick17
      I am trying to perform an FSI simulation in Fluent. The problem that I am currently working on is that when the walls undergo large deformation, the boundary layer elements become distorted and the simulation stops because of the negative volume elements error. Is there any way to maintain a good quality of boundary layer elements other than adjusting the diffusion parameter?
      Thank you.
    • Keyur Kanade
      You may want to change inflation parameters.
      Please check following videos
      Ansys Meshing: Inflation:
      https://www.youtube.com/watch?v=lrEHXizrhC0
      If possible, you can remove inflation and use only tet or hex elements.
      Regards Keyur
    • Rick17
      Got it! Thank you very much for your help.
      Kind regards
  • The topic ‘How to perform remeshing for 3D boundary layer elements’ is closed to new replies.
