December 12, 2024 at 3:11 pmpatrick.steinerSubscriber
Hello I try to model a (partly) particle filled pipe and with a coupled cfd flush it with water and smaller particles. The target is see the clogging of the coaser particles and its influcence to the fluid flow. There is a similar video on the web https://www.youtube.com/watch?v=UHEWGA_omUw)  I check the all the tutorials and also the 2way coupling is working. But I'm really struggling with the plate or boundary which fixes the filter particle in the tube. I found a older written tutorial where is say the is an option to set a plane as obstacle, but I cant find anything like this. Could someone explain to me how they did the trick in this video?
Cheers Paddy
December 12, 2024 at 3:28 pmRobForum Moderator
If it's coupled just set the grate as a porous jump in Fluent and wall in Rocky.Â
- Non-Intersected faces found for matching interface periodic-walls
- error udf
- Cyclone (Stairmand) simulation using RSM
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Fluent fails with Intel MPI protocol on 2 nodes
- Encountering Error in Heterogeneous Surface Reaction
- Script Error
1171
488
487
225
201
