May 17, 2026 at 1:11 pm
aniruddhabose96
SubscriberHi
I have DPM of solid particles in a pipe flow. How can I calculate the number of particles in each cell at every time step? There is a variable DPM Particles in Cell but it cannot be visualised on the entire 3D pipe volume. What can be done?
May 18, 2026 at 7:39 am
Forum ModeratorHow do you plan on counting parcels that pass through more than one cell? You could dump particles in cell to a UDM and then export an interpolation file: you'll have the number and a cell centre location.Â
May 18, 2026 at 3:58 pm
aniruddhabose96
SubscriberIf i export the variable called 'DPM particles in cell' from CFDPost then does it give the number of particles in each cell? When i export the data it gives x,y,z coordinates and a number which is sometimes fractional. But DPM particles cannot be fractional. Am i doing the right thing? I could not understand the UDM part.
May 18, 2026 at 4:02 pm
Forum ModeratorIf you check the DPM Particles in a Cell when documentation is back up what does the definition say?
May 18, 2026 at 4:19 pm
aniruddhabose96
SubscriberI have the offline users guide-it says that it is the cell averaged property. So it is not the actual no of particles-are you saying this? It is the discrete value interpolated over the mesh to create a contour. So it wont give the correct value? Am i right?
May 19, 2026 at 8:22 am
Forum ModeratorIt's a weighted value: read the definition in the 26R1 manual very carefully. It is also correct based on the definition - it may not be the value you want, but it's the value as defined in Fluent.Â
6635
1312
