July 29, 2021 at 6:57 am
zahrakhanom
Subscriberhello all
i simulated a geometry in ansys cfx, i want define thermal conductivity that is function of three variables,these variables are in an excel file in each time step, so ansys should read theses variables in each time step and replace in thermal conductivity correlation. can do it?
thanks
July 29, 2021 at 9:31 amAmine Ben Hadj Ali
Ansys EmployeeFor 4D Profiles you require User Fortran.
if you have few time steps one can try creating a time interpolation of the spatial profiles directly in Ansys CFX.
What are your variables?
August 5, 2021 at 8:04 amzahrakhanom
Subscriberthanks, variables are time and void
August 5, 2021 at 8:36 amAmine Ben Hadj Ali
Ansys EmployeeSo a void profile depending on time only? Do you want to use it as inlet condition?
Viewing 3 reply threads- The topic ‘how ANSYS CFX setup reads an excel file in each time step?’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
Top Contributors-
4512
1494
1386
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
