October 2, 2024 at 7:32 pm
Artek.Chalifour
SubscriberHi all! I'm trying to find info on the incident plane wave excitement node and am coming up short. Specifically, I am looking at the difference between the total vs scattered option in the Incident Field Formulation option.
For example, why does the former allow an Infinite Ground Plane in the geometry where the latter does not? And why does the field look so different for each? (mag_E plotted in second pic at 45 degrees for incident field only of each case)
November 21, 2024 at 9:34 am
Aymen Mzoughi
Ansys EmployeeIncident+Scattered = Total
That's why if expected Total=0, Scattered should be opposite to Incident
You can more information about this in the online help:
https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/Electronics/v242/en/Subsystems/HFSS/HFSS.htm%23HFSS/SummaryforTotalandScatteredFields.htm
Just a reminder that you may use Ansys Community Feed to develop your network and foster community by joining the appropriate community group and making connections. If you are interested in Electronics content, please join the Electronics group (link - https://innovationspace.ansys.com/community/groups/?electronics-community/)
- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- Simulation of capacitor combining eddy currents with displacement currents
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- Maxwell circuit – PWM
- Plotting Ex, Ey and Ez in vector forms individually
- Ansys-MATLAB Co-Simulation
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
1932
823
599
591
366
