July 22, 2024 at 1:28 pmalexandre-antoi.bourrieauSubscriber
I have a microstrip with a terminal voltage at total = 1V with port impoedance set to 50 ohm:
I want to calculate port impedance using Field Calculator : Zpv = V²/P.
For calculating V, I integrate E along the line :
using this formula :
and I got 1V so it work OK:
For calculating P, I integrate Poyting vector on this surface :
But after dividing quantity, I don't got 50 ohm but 318 ohm :
So it seems that my value for P is wrong no ?
Thanks you !
September 16, 2024 at 2:11 pmAymen MzoughiAnsys Employee
HFSS can directly compute the port impedance so there is no need to go through the field calculator
Ansys Innovation Space
- Polarization and Angle of Incidence Scan with Floquet ports in ANSYS HFSS
- How to create Lumped RLC in HFSS to match Circuit? (Simulate load as Lumped RLC)
- CPW resonant frequency HFSS Simulation
- EMA3D Current Source Problem
- Setting up CPW HFSS Simulation
- Simplorer link to Maxwell transient
- Help on calculating port impedance Zpv using Field calculator under HFSS please
- Question for Maxwell
- HFSS Incident Plane Wave excitement mode
447
396
225
201
