December 6, 2024 at 9:22 pmadib.aktab999Subscriber/prep7Â! Define Neo-Hookean material model for the solid skeleton (already defined)! Elastic modulus: 0.06 MPa, Poisson's ratio: 0, Initial shear stress: 0.03 MPaÂ! Define porous media propertiesTB,PM,7,,PERMÂ ! Activate porous media definition for permeabilityTBDATA,7,45037Â ! Permeability value (isotropic)ÂTB,PM,7,SPÂ ! Define solid properties for the skeletonTBDATA,7,0.06,0Â ! Bulk modulus of solid skeleton (0.06 MPa), specific weight (set to 0 if not used)TB,PM,7,FPÂ ! Define fluid propertiesTBDATA,7,0,0,0.45Â ! Bulk modulus of fluid (0 for incompressibility), specific weight of fluid, porosity (1 - solid volume fraction)Â! Note: Biot coefficient and Biot modulus are left undefined (default: Biot coefficient = 1)
this apdl creates a error:*** ERROR ***              CP =    2.781  TIME= 03:14:50 TB,PM,,, has already been defined. Please delete existing table to  Â overwrite                               Â NUMBER OF WARNING MESSAGES ENCOUNTERED=     0 NUMBER OF ERROR  MESSAGES ENCOUNTERED=     1ÂHow can I fix it? -
December 9, 2024 at 7:48 amErik KostsonAnsys Employee
Hi
I think the ** error ** msg tells how to fix it :).
Look at help manual command ref, for TB related commands to do what it says
Erik
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
555
366
