Topics relate to Fluent, CFX, Turbogrid and more
gradient adaption
    • A1234
      Hellonwhen i use gradient Adaption .the second time step has big Courant number and then strat to less.why?how can i solve it?ni simulate drop impact and its transition.what is the best gradient adaption ferquency?nwhen i use 10 or smaller my solve is not converge?n
      When you adapt the mesh you more-or-less half the cell length (look at the adaption section in the User's and Theory Guide), this obviously has implications for the courant number. At the same time the refined mesh may pick up some new flow features further reducing the time step required for stable solving. Have a look at the flow field and reduce the time step to suit. Adaptive time stepping can work in some cases, but with dynamic adaption you may find it changes too quickly for the solution: fixed tends to be a little slower but much more stable. n
    • A1234
      thanksn
    • A1234
      nhow can i choice best frequency ?nDoes it have a formula?n
    • DrAmine
      It does not have a formula. Best to do it frequently if you need to have a crisp interface.n
      I'd suggest somewhere between 10-20. Too often and you slow the solver down with unnecessary remeshing, too infrequently and as says you'll lose the interface. n
Viewing 5 reply threads
  • The topic ‘gradient adaption’ is closed to new replies.
