February 7, 2023 at 5:12 amabhnv_01Subscriber
I am trying to simulate a heat pipe in (2D) which has three sections:
- Evaporator - Constant heat flux (boundary conditions)
- Condensor - Constant temperature (boundary conditions)
- Adiabatic section - Zero heat flux (boundary conditions)
I am using VOF multiphase model -> Evaporation - condensation model -> Lee model.Â
Transient simulation with gravity and implicit body force formulation.
Time step size = 0.0001 (1E-04).
The simulation works well for first 10000 time steps (1 seconds of flow time) and then this error where global courant number exceeds 250.Â
But here is a mystery, the simulation runs well with constant temperature boundary condition at the evaporator.
I want results with constatn heat flux, I am not able to track the error, any help will be highly appreciated.Â
February 7, 2023 at 6:05 amSRPAnsys Employee
I suggest to try variable time stepping in order to automatically change the time-step. It is better to use the variable time stepping method to control the CFL under limit. The solution will be stable with the variable time stepping method.
Thank you
Saurabh
- The topic ‘Global courant number exceeds 250 for constant heat flux bcs.’ is closed to new replies.
421
192
178
162
140
