Electronics
Electronics
Getting problem in Interpolation Sweep, It is not getting converged.
    • RituS
      My design has about 20 ports, Solution frequency is 3GHz & the frequency sweep is from 27MHz to 6GHz.
      Interpolation error tolerance is 0.5%.
      But, the minimum error that I am able to achieve is 2%.
      Any recommendation? What might be the problem?
    • Praneeth
      Can you try adding different sweeps for each of the bands you defined instead of defining them in a single sweep?
      Best regards.
  • The topic ‘Getting problem in Interpolation Sweep, It is not getting converged.’ is closed to new replies.
