FLUENT: Using DEFINE_GEOM and CG_MOTION to deform 2d geometry
    • ystein
      Hi All,
      I am essentially trying to deform a square into a rhombic shape to study it's shearing properties as this picture:
      My created geometry is below, where I would be pulling the four rounded corners of the square to deform . I would then want the walls to slide at different slopes to stretch into the rhombic shape. The walls have to be straight lines, but the logic is that all I am doing is changing the slope of the walls given the positions of the corners.
      Therefore, I have chosen CG_MOTION to define the motion of corners and DEFINE_GEOM to define the motion of the wall.
      Unfortunately, when I hook in deforming zones for the walls, I cannot display ZONE MOTION of the corners! Nothing shows up in the display. When I preview mesh motion, my geometry doesn't exist anymore. It displays as such:
      It is the skeleton of my geometry used to create the mesh zones. I don't know what's happening!
      This is what it says in the TUI:
      Dynamic Mesh Statistics:
      Minimum Volume = 5.92234e-02
      Maximum Volume = 3.64152e+00
      Maximum Cell Skew = 5.01364e-01 (cell zone 3)
      Minimum Orthogonal Quality = 0.00000e+00 (cell zone 3)
      Warning: minimum orthogonal quality less than 0.05.
      Warning: left handed faces detected!
      This is my UDF code:
      CGMOTION:
      define geom: I use a slight variation of this for every wall but the backbone is the same.
      Any help is appreciated. I should also note that "display mesh" is checked in mesh motion. After I run the preview, If i go back to mesh display, I cannot recover my original mesh.
      I can also provide other screenshots of my dynamic mesh zones if needed! Thank you.
    • ystein
      ok so update:
      I now added the interior body to also be deforming, but this is my result before negative cell volume is detected.
      Any suggestions to improve mesh? / reasons for why the walls aren't changing slopes?
  • The topic ‘FLUENT: Using DEFINE_GEOM and CG_MOTION to deform 2d geometry’ is closed to new replies.
